Possible bug in ADC of dsPIC30F6010A
Hi Lubin!
Could You check connections of pin AN7 and AN3 in your blockset? It's very strange, but when I want to convert AN7 analog input, dsPIC is converting different value than it's real. I checked all connections in my PCB and that value is on pin AN3. Is this possible, AN3 and AN7 are changed places?
Blockset version 0.98
Re: Possible bug in ADC of dsPIC30F6010A
Hi Nigma,
This would be quite surpising to have an inversion on pin AN7 ==> AN3.
Could you upload the model (.mdl file) so as to have a look ?
What are the parameters for Vref+ and Vref- ?
I used AVdd - AVss.
The generated code for the configuration of the ADC with your model is :
To read the converted values, the code is :
If there is something wrong with that, I would be glad to correct it.
</i> 124 /* S-Function "dsPIC_ADC" initialization Block: <Root>/ADC Input */
125 /* Initialise ADC converter */
126 /* 0 mean each 1 conversion */
127 #define NoSamplesADC 1
128 #define ADCSval 3
129 #define SAMCval (1 << 8)
130 #define OutFormatBitsval (0 << 8)
131 #define VoltRef (0 << 13)
132
133
134 ADCON1 = 0x00E4 | (0 << 10)| OutFormatBitsval;
135 ADCON2 = 0x0400 | (NoSamplesADC << 2) | VoltRef;
136 ADCSSL = 144;
137 ADCON3 = (ADCSval | SAMCval) & 0xff7f;
138 ADCHS = 0x0000;
139 IPC2 = (IPC2 | (6 << 12)); /*Interrupt Priority : 6*/
140 _ADIF = 0;
141
142
143
144
145 /* Turn on ADC Module */
146 ADCON1bits.ADON= 1;
</i> 39 /* S-Function "ADC" Block: <Root>/ADC Input */
40 Gyro_test_B.ADCInput_o1 = ADCBUF0;
41 Gyro_test_B.ADCInput_o2 = ADCBUF1;
