undefined reference to `sbrk'
I've spent much of the day today trying to debug this error with no luck:
The strange thing is that it happens once the memory usage map has been printed, that is almost at the end.
Any idea what the problem might be?
</i>C:\PROGRA~1\MICROC~1\MPLABC~1\lib\libc-coff.a(xgetmem.o)(.libc+0x4):/home/guymc/build/3.10/build_20080424/src/standardc/sxl/xgetmem.c: undefined reference to `sbrk'
C:\Program Files\Microchip\MPLAB C30\bin\bin/pic30-coff-ld.exe: link errors found, deleting executable `..\../GPSRead.coff'
gmake: *** [..\../GPSRead.coff] Error 0xff
### Real-Time Workshop build procedure for model: 'GPSRead' aborted due to an error.
Re: undefined reference to `sbrk'
I finally solved this issue. It turns out that malloc and memcpy use sbrk which for some reason it is not compiled into the coff. Anyways, I found in the periphereal library documentation that microchip provides the source for sbrk with the standard C30 instalation, so I just added the source to the Simulink project and then it compiled fine.
Hope this helps anyone with similar problems
