Two UARTs in a single model
I'm trying to use the following model to test my hardware setup for using both UARTS. Unfortunately I get an error stating "Error using ==> dsPIC_UART_RX_callback at 76\nProblem".
I've attached the model I'm using for you.
Re: Two UARTs in a single model
Thanks for repporting the problem.
Problem is now solved and will be available in next blockset version (following v3.4b)
Hi Lubin, I am experienceing the same problem using two UART on pic24fj128ga010. The version of the blockset I have is 3.4bc. is this the one you are reffering to or I need to get the update?
Addition error mesage is "index exceed matrix dimension"
