"link errors found"
"link errors found"
Slashes in the path ,as you see, are different. I think thats why the compiler has the link error. How can i handle this problem.
c:\program files\microchip\mplab c30\bin\bin\..\bin/pic30-coff-ld.exe: link errors found, deleting executable `..\../analog_read.cof'
==Emre==
==Emre==
Re: "link errors found"
Hi Emre,
Usually, / and \ would not be a problem for the Microchip C30 compiler.
Is si notmal you compiler path has two bin folders ?
c:\program files\microchip\mplab c30\bin\bin/pic30-coff-ld.exe
That might cause the link error ?
Hello Mr. Lubin,
You are right. I copy the files in the second bin folder to first bin folder. Now it works fine. Thanks a lot.
==Emre==
==Emre==
