PWM simultaneous switching problem
I previously had no problem running the motor PWM block in "2 quadrant" mode, i.e. PWM only of the high side switches. I would now like to operate in "4 quadrant" mode, with simultaneous PWM of both the high and low side switches (but not using complementary switching).
I cannot find a way to enable both high and low switches for PWM without having complementary output enabled (which I do not want).
I know that this is possible because if I manually edit the following line in the code it works fine:
#define config2 (0xffff & PWM1_PEN1L & PWM1_MOD1_IND & PWM1_PDIS1H & PWM1_PEN2L & PWM1_MOD2_IND & PWM1_PDIS2H & PWM1_PEN3L & PWM1_MOD3_IND & PWM1_PDIS3H)
Removing the PWM1_PDISxH parts allows me to achieve what I want.
Is this a bug?
Is this a bug?
