DsPIC Block/I2C Master
Block I2C Master
I2C Master Dialog
Ref I2C
Alternative I2C pin
This option is display when the dsPIC has an alternative I2C pin option. All I2C blocks must have the same configuration. Either this option is checked in all of the I2C blocks, neither none of them are checked. Mixing both will result in chosing randomly one of the PIN configuration and may also provide unexpected behaviour.
Sequence
Initialisation
- Both
- None
Wait after enable
Place a number or No OPerating (nop) instruction after re-enabling the I2C BUS. This is to avoid problems du to fast transition.
I2C bus frequency
Slew rate active
Activate Slew rate
Enable SMB bus threshold
Output Error flag
