TECHNICAL WIKI
DsPIC Block/Master
Master Block
Master Block
Master Block Dialog for the 30f3012 chip, General Tab
Master Block Dialog for the 30f3012 chip, Quartz Tab
Step Based on
  • Tmer1 : The model time step is set using the Timer1 automatically configured (Prescaler and PR1).
  • ADC : The ADC conversion time can be used only when the ADC block is set to produce two or more sample per channel. The conversion time is 'augmented' so as to have reach the model time step at the end of all conversion needed in 1 time step.
  • Free Run : The model execute at its maximum speed. The Time step is not constant since the calculation time may changed slightly between time step. The simulink model time step is not taken into acount.
PIC
59 Supported devices :
PIC 24FPIC 32F**PIC 30FPIC 30FPIC 33FJ GPPIC 33FJ MCPIC 33FJ GPPIC 33FJ MC*
24fJ128GA006
32MX360F256L
30f2010
30f5011
33fJ128GP206
33fJ256MC510
33fj128GP202
33fj128MC202
24fJ128GA008
32MX360F512L
30f2011
30f5013
33fJ128GP306
33fJ256MC710
33fj128GP204
33fj128MC204
24fJ128GA010
32MX460F256L
30f2012
30f5015
33fJ128GP310
33fJ64MC506
33fj128GP802
33fj128MC802
24fJ64GA006
32MX460F512L
30f3010
30f5016
33fJ128GP706
33fJ64MC508
33fj128GP804
33fj128MC804
24fJ64GA008
32MX775F256L
30f3011
30f6010
33fJ128GP708
33fJ64MC510
33fj32GP302
33fj32MC302
24fJ64GA010
32MX775F256L
30f3012
30f6011
33fJ128GP710
33fJ64MC706
33fj32GP304
33fj32MC304
24fJ96GA006
32MX795F512L
30f3013
30f6012
33fJ256GP506
33fJ64MC710
33fj64GP202
33fj64MC202
24fJ96GA008
32MX320
30f3014
30f6013
33fJ256GP510
33fJ128MC506
33fj64GP204
33fj64MC204
24fJ96GA010
32MX340
30f4011
30f6014
33fJ256GP710
33fJ128MC510
33fj64GP802
33fj64MC802
24fJ16GA002
30f4012
30f6015
33fJ64GP206
33fJ128MC706
33fj64GP804
33fj64MC804
24fJ32GA002
30f4013
33fJ64GP306
33fJ128MC708
33fJ64GP310
33fJ128MC710
33fJ64GP706
24fJ16GA004
33fJ64GP708
24fJ32GA002
33fJ64GP710
Time Step  reference is Timer 1. Timer 1 prescaler and PR1 register are configured  so as to meet the time step set in Simulink. When Timer 1 reach PR1, it  is reset and a next step is started.
Time  Step reference is the ADC peripheral. ADC conversion are slowed down so  as to meet the time step requirement set in Simulink. On this example,  Three channels are converted ; Two sample are read at each step (i.e.  the three ADC blocks output are vectors of 2 elements each).
Time  Step in Free Run mode. The model is executed as fast as it can. The  time step set in Simulink is not respected.
For 30f family microcontroller
You must compute yourself the Instruction Per Seconds using :
IPS=FreqQuartz4*PLLfactorIPS = \frac{FreqQuartz}{4} * PLL_{factor}
With FreqQuartz the frequency of the source (Quartz or internal oscillator, External Clock ...) and with PLL factor set to 1 when PLL multiplication is not used.
For 24, 33 and 32 microcontroller
: From the entered Desired Instruction Cycle Frequency, the toolbox compute the best PLL multiplication which provides the Instruction Cycle Frequency the closest to the Desired one.
Config Timer
Busy Flag Port
Overload Flag Port
config Oscillator mode
config Born Out Reset
config Power Time
config MCLR
