TECHNICAL WIKI
DsPIC Block/Output Compare HW
Block Output Compare
Outline
Output Compare Dialog
  • Allow generation of very fast PWM signal
  • Possibility to set accurately the ADC sampling time at any instant of the PWM period.
  • All PWM channels have the same Period (however, mode and duty cycle can be different)
  • The peripheral will not be able to share the timer it uses with others peripheral
  • Time Up and Period
  • Time Down and Period
  • Time Set and Reset
Up or Down or Periode = Tset*OCmaxMaxChannelT_{set} * \frac{OCmax}{MaxChannel}
With
  • MaxChannel = The literal value (in second) you defined as the max time in the dialog box
  • OCmax = a constant automatically evaluated in the matlab workspace
for example, if the max value is set to 20ms (MaxChannel = 2010−32010^{-3}) on channel 1
110−3OC1max2010−3110^{-3}\frac{OC1max}{2010^{-3}}
Output Channels
Channels Input Type
  • 5 : set UP duty cycle and Period
  • 10 : set Down duty cycle and Period
  • 16 : set rise and fall time instant within the period (useful when using ADC)
Periode as block input
Period Max
Related block & Examples
Related block:
Examples:
