TECHNICAL WIKI
DsPIC Block/SPI Configuration
Block SPI Configuration
SPI Configuration Dialog
n° SPI
SPI used
Mode
Master or Slave : define who is driving the clock signal
Prescaler
SDO Enable
Data length
Slave Select Pin Enable
Sample phase
Clock Active State
Output change on transition
