TECHNICAL WIKI
DsPIC Block/SPI Input Output
Block SPI Input/Output
SPI Input Output Dialog
Example of SPI block reading data from an rate-gyro (ADIS16100). Chip Select of the rate gyro is connected to the B4 dsPIC pin which is activated just before execution of the SPI block. Note the Ordering connection to force block ordering.
n° SPI
SPI used
SPI Input
SPI Output
Special SPI
  • Always Enable
  • Disable After block execution
  • Re-Enable before block execution
  • Re-Enable Execute and disable
Data Length
