DsPIC Block/UART Configuration
Block UART Configuration
UART Dialog, Tab General
- 1 stop bit
- 8 bits data
- no parity
- no flow control
UART to be used
Main
Baud (kb/s)
Tx Rx Alternativ
TXEN
Tx Interrupt
UART Dialog, Tab Tx
Tx Interrupt take place
Tx Interrupt Priority
Tx Interrupt buffer size
Rx Interrupt
UART Dialog, Tab Rx
Rx Interrupt take place
Rx Interrupt Priority
Rx Interrupt buffer size
