Explorer 16 Board
- One led (Port A7) :
Set UP
Simulink
PIC
Master block configuration
Open the Master block.
Set up PIC peripheral
Digital Input Configuration
Digital Output Configuration
ADC Configuration
UART
UART Peripheral Configuration
Functions
Blinking Leds
Filtering
https://www.kerhuel.eu/RTWdsPIC/examples/Explorer16DevBoard/html_Hex_Matlab2007a/dsPIC_33f_Explorer16_codegen_rpt.html Report https://www.kerhuel.eu/RTWdsPIC/examples/Explorer16DevBoard/html_Hex_Matlab2007a_24fj/dsPIC_33f_Explorer16_codegen_rpt.html Report https://www.kerhuel.eu/RTWdsPIC/examples/Explorer16DevBoard/html_Hex_Matlab2007a/dsPIC_33f_Explorer16.hex Hex file https://www.kerhuel.eu/RTWdsPIC/examples/Explorer16DevBoard/html_Hex_Matlab2007a_24fj/dsPIC_33f_Explorer16.hex Hex file
Log and Plot Data
Pic side
Computer side
