TECHNICAL WIKI
Flex Board Blinking Led
Flex Board equiped with a dsPIC33Fj256MC710, from Evidence Srl
Model Configuration
download the model
download the model
UART is configured with its maximum speed (for the PC) i.e. 115200 bauds. This UART speed cannot be achieved without enabling the dsPIC clock multiplier PLL. Without PLL, the microcontroller run at 2MIPS and the UART speed error (read from the UART configuration block) is of 8.5%. Therefore, PLL is activated. The targeted speed must be compatible with the UART baud used. With a configuration of 9.2MIPS, UART has a speed error of -0.17% (The real baud is 115000 ; error is : 115000โˆ’115200115200=โˆ’0.0017\frac{115000 - 115200}{115200} = -0.0017)
Matlab Graphical User Interface to send and log data to and from the Flex Board
Sinus with variable amplitude logged from the Flex Board throught UART
  • the variable 60 set the amplitude of the sinus generated.
  • the variable 61 define which data is send to the PC :
    • if 0, the Time Step is being sent
    • if 1, the Sinus is being sent.
  • the variable 62 is directly sent to the PC
Time Step. From the Master block, the 2ms time step correspond to a value of 18399. Real time constraints are respected.
450018399=0.25\frac{4500}{18399} = 0.25
Thanks to Evidence for providing this Flex Board Light.
Category:Example
