TECHNICAL WIKI
Pic32-gcc v1.04 bugfix
Bug reported on the Microchip .h definition file.
  • In the file int.h localised in \MPLAB C32\pic32mx\include\peripheral\int.h,
  • Lines (411, 424, 437, 450, 463) replace
INTCONbits
by
INT0CONbits
  • Line 705, replace
#define mOC1SetIntPriority(priority)        (IPC1CLR = _IPC1_OC1IP_POSITION, IPC1SET = ((priority) << _IPC1_OC1IP_MASK))
by
#define mOC1SetIntPriority(priority)        (IPC1CLR = _IPC1_OC1IP_MASK, IPC1SET = ((priority) << _IPC1_OC1IP_POSITION))
  • Line 746, replace
#define mOC4SetIntSubPriority(subPriority)  (IPC4CLR = _IPC4_OC4IS_MASK, IPC4SET = ((subPriority) << v))
by
#define mOC4SetIntSubPriority(subPriority)  (IPC4CLR = _IPC4_OC4IS_MASK, IPC4SET = ((subPriority) << _IPC4_OCIS_POSITION))
Thanks to Jiri Sehnal from Humusoft for identifying theses bugs.
Category:Compiler_BugFix
